Mappers.
1st. Not that i know anything about pitch bend but i'll describe what iam thinking. How do you set pitch bend so you can specify what number you want the pitch bend to start at, so you can get a negative/reverse type effect rather than just pitch bend from 1, on encoder, increases goes positive so you can slow the song right down and even go into reverse.
2nd. Does select work. I have mapped it to a encoder on my MIDI controller yet it doesn't work i mapped it with the old mapper engine and it worked fine with a encoder for select, even though i used a button to map select to check and it still doesn't work.
3rd. Why can't you have two different decks for loop. ie have 'loop 1 beat' deck 1, loop 1 beat' deck 2. You have to select the deck then use the button to set the loop, what if i want to loop both songs simultaneously at the same time and cut the loops down together for instance, i can't, where i would want to, or do whatever else.
geposted Thu 24 Sep 09 @ 2:22 am
4th. Can virtual dj 6 be set up to register values either side of 65, like the old VDJ5...
5 just for the record. What is actual length, in reference to 'set the length in beats to the "actual length"'
geposted Thu 24 Sep 09 @ 3:53 am
You need to read the Wiki ... or just ask for the syntax to accomplish what you want to happen ..
For example ... this makes no sense to what you are trying to do ...
https://virtualdj.com/wiki/VDJscript.html
https://virtualdj.com/wiki/VDJscript_verbs.html
First - what controller are you using ??? And if you are trying to use only the Simple_MIDI mapper to do complex controls then you will run into limitations on what you are actually able to do. So of the complex actions require the device to be defined using a definition file in order to perform more complex tasks.
#1 - Are you using a button / encoder / slider / jog ?? What are you using that you want to apply the pitch bend action to?
#2 - 'select' requires a prefix action of 'deck' to identify what you are selecting - deck 1 select or deck 2 select
#3 - Huhh? "two different decks for loop" ?? I think I understand what you are trying to say ... deck 1 loop 1 & deck 2 loop 1 ... if you want 1 button to act on each deck at the same time then you have to spell it out - otherwise by default the action only acts upon the active deck.
#5 - Just for the record ... Set the length in beats to the actual length ... actual length is the value you are applying - loop 4 <- 4 is the actual length you are setting the loop's length too.
geposted Thu 24 Sep 09 @ 7:59 am
Ahh too much too think about and problems, i meant 64. By that i meant there is no option in VDJ 6 to select +, - 64 controller encoder preset at 65 and min value at 63 and max at 65...
Definition file. None of this was like this is VDJ 5, it was alot more user intuitive.
How do use a definition file, whatever.
Encoder. . .. ?
See none of this is VDJ 6, VDJ 5 you had it all right there.
Yes.
See none of this is in VDJ 6, is there like some script which tells you all the prefix's,...?
Thank
geposted Thu 24 Sep 09 @ 9:42 pm
And you must have stopped at the first part of my post because your answer is still in coherent.
So ... before we go any farther ... explain the following - because you are over complicating your question because you don't understand the new mapper engine ....
geposted Thu 24 Sep 09 @ 9:49 pm
I was still editing :-
geposted Thu 24 Sep 09 @ 9:50 pm
Even with you editing ... you still didn't answer the question ...
What controller are you trying to configure?
And V6 is here ... it is more advanced and more configurable that V5 and the new mapper engine is easier if you give it a chance.
Also ... to answer one of your questions ... you need to slow down and visit the links that I provided above ...
Also ... you need to stop answering the questions with rambles ... none of the replies have any substance that can be understood ...
So again .. what is the controller you are trying to map?
geposted Thu 24 Sep 09 @ 10:00 pm
I did say BCR but i didn't think it mattered whatever.
I know V6 is here that is why i am complaining whatever about VD6 mapper engine and posting all these questions whatever.
I post prematurely because i do because my head trys hard to understand the VDJ6 and VDJ 5 difference.
Fine i will slow down.
Was the change from the VDJ5 mapper engine whatever nessesary to change to the VDJ 6 mapper engine.
P.s it is hard to type and get acrorss what you mean when you when you have problems can;t get to where you wan't to there is too much problems to describe.
what i am typing may not be how it is read.
geposted Thu 24 Sep 09 @ 10:57 pm
P.s 'select "deck 1"' still does't work
geposted Thu 24 Sep 09 @ 11:31 pm
p.s there is no way iam going to be able to understand all that. You have to be a computer programmer to understand all that i mapped the controller to my old device ages ago on VDJ 5 and had no worries.
geposted Thu 24 Sep 09 @ 11:37 pm
Again .. you are not reading and paying attention to what is being said ... I gave you the answer and you still took your own route ...
This is what I typed - deck 1 select or deck 2 select
Where do you see -> select deck 1 ???
Well it does matter if you want help ... don't you think?
Also, what is a BCR ??? Never heard of it.
You still continue to post in 'generics' and not being specific -- and then you ask questions that have nothing to do with your problem ....
What does this question have to do with getting you answers to your problem? Yes, it was necessary - we would not have done it if it wasn't.
Well that is why I said - slow down. You still will not answer my questions with specifics and you don't ask your questions with specifics.
We what I read is you questioning why we made the changes and not what you are needing help on ... and in some cases it is like you are leaving every other word out because what you type does not make sense - hence my point of saying they look like rambles.
And you don't have to be a programmer to understand all this ... you are making it more difficult then it has to be.
So ... again ... just reply with this 1 answer to this 1 question --
What is the actual make and model of the controller ?
geposted Fri 25 Sep 09 @ 11:41 am
You will need to make a controller definition for advanced functions such as endless encoder knobs, jogwheels and LED's to function correctly: https://virtualdj.com/wiki/ControllerDefinitionMIDI.html
Simple MIDI Wrapper as its name implies only supports very basic MIDI mapping - Simple notes, sliders and standard knobs with min/max stopping point (E.g: Volume, bass, treble, etc.)
To toggle between the two decks on a single deck controller, use: deck active select - This needs to be assigned to a button.
geposted Fri 25 Sep 09 @ 12:43 pm
I thought.. I think i was thinking the verb had to go in front.
Behringer BCR.
Its a behringer BCR 2000.
geposted Fri 25 Sep 09 @ 10:32 pm
The Behringer BCR 2000, while a USB mixer, was not intended as a DJ mixing unit. It was designed more for bands/small studio work.
geposted Fri 25 Sep 09 @ 10:42 pm
Yeah but i still mapped it on the old VDJ.
geposted Sat 26 Sep 09 @ 12:30 am
Yeah the verb deck does go in front i must have go confused with parameters.
geposted Sat 26 Sep 09 @ 12:37 am
How come sync doesn't work with deck
geposted Sat 26 Sep 09 @ 2:41 am
