ok do i need ones of these?
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=145944
or do i need other stuff in able to do this
plz help
geposted Fri 22 Apr 05 @ 7:46 pm
Sprice are you using the Demo version? Because if you are then the pre-listen will not work. It works only on the Full Version.
MS
MS
geposted Fri 22 Apr 05 @ 7:55 pm
