Forum: Music discussion
Topic: hot cue vs cue
could anyone explain the difference between hot cues and cues?
geposted Sat 26 Sep 09 @ 1:52 am
dglitoPRO InfinityMember since 2006
Hot Cue is for create a Cue Point and Cue is for go at some of your hot cue that you have placed.
geposted Mon 28 Sep 09 @ 7:44 am
ReThinkPRO InfinityMember since 2009
More specifically the hot_cue is for setting a cue while the song is playing whereas the cue can only be set when the song is stopped. As for play back, hot_cue will play from the cue point and cue will only play as long as you hold the button down.
Hope this helps
geposted Tue 13 Oct 09 @ 8:23 pm
yes,thanks
geposted Thu 15 Oct 09 @ 9:36 pm
