I may be missing something very simple but i am having troubles with version 2.06 and the maya 44 usb.
I have setup the TCV to work though the inputs 1-4 and they all work fine. When i go into the advanced audio setup and i select the maya 44 usb asio driver, i select 0 and 1 for the LEFT table, and 2 and 3 for the RIGHT table, but i cannot seem to get them to output anything. I have the Maya 44 2.5.5 driver, the newest one, and everyting seems to be setup correctly.
geposted Sat 23 Apr 05 @ 9:34 pm
neptunekiev -- check this thread for a baseline setup of the Maya44 for TCV use -- https://virtualdj.com/forum/display.html?topic=11086 - about 4th post down.
Also, dude if you are using a legit version of 2.06 then register your stuff. It will save you alot of headaches when asking for help.
cstoll
cstoll
geposted Sun 24 Apr 05 @ 12:57 am
