Hey all,
Sorry for the ignorance in this post, pretty rubbish at this whole technology lark which makes trying to set up my pioneers with my computer an almost impossible task.
I bought Traktor (probably foolishly) thinking that it would work perfectly with my two cdj-400s. However unfortunately when everything was hooked up, the lights didnt work on the decks, nor the screen on the top nor the effects. Before i make the mistake of buying another product, i was wondering whether with Virtual DJ, if i manage to set them up correctly, all of this will be functional or am i fighting a losing battle.
Any tips will be of great help,
If it makes a difference, im on Vista.
Thanks a lot in advance, appreciate it and sorry for my stupidity
geposted Tue 29 Sep 09 @ 2:57 pm
This might help you ... https://virtualdj.com/forums/114207/General_Discussion/VDJ_and_Pioneer_CDJ-400s_on_PC_video.html
geposted Tue 29 Sep 09 @ 4:02 pm
thanks mate, thats actually really helpful and should hopefully make it much easier to set up (these things are so difficult i know! sorry to be annoying but nowhere in the video did it say whether the lights / screen / effects work with Virtual DJ, just want to make sure thats true before purchasing another product.
Thanks
Thanks
geposted Tue 29 Sep 09 @ 8:40 pm
