I just purchased a Korg Zero 4 and it should arrive by Monday. Is there anything about this mixer that I should know? any special things that I need to get everything to work properly. Any downloads, patches...anything?
geposted Wed 30 Sep 09 @ 2:01 pm
Latest Firmware for the Korg Zero 4 is Version 1.6 (03/2008) (But your mixer should also have the latest update)
Latest driver for the Korg Zero 4 is Version 1.1 You can find the it here http://www.korg.co.uk/downloads/driver/FW/KORG_Firewire_Driver_v110.zip
Some user had some problems with installing the Korg Zero 4 or losing connectivity after they had installed it. Sometimes a new cable worked but sometimes it was an issue with the built in firewire card. In my case installing the zero worked (Laptop) but after some minutes i lost connectivity. The solution was that i bought a PCMCIA Card with Firewire connections. But could also be an issue with windows vista because I had Windows XP at first and had no problems with the Zero4. And with vista it was a disaster ;)
geposted Thu 01 Oct 09 @ 11:31 am
If you use timecode CD's make sure you download the Korg Traktor Adapter. See: http://www.virtualdj.com/forums/111258/Hardware_Technical_Support/Korg_Zero_4_TimeCode_Help_.html
Also if you have poor audio performace, try this third party OHCI 1394 driver:
From: http://www.alliedvisiontec.com/downloads/avt-software/avt-1394-bus-driver-package.html
"Currently the native 1394 bus driver of Microsoft Windows is mainly suitable for controllers and devices that are compliant to the 1394a standard. The features introduced with the 1394b standard often cannot be used in Windows based applications and device drivers. Furthermore, there are some known stability issues that cause problems in industrial and professional applications with high reliability demands"
thanks,
David (DJ Kavika)
thanks,
David (DJ Kavika)
geposted Thu 01 Oct 09 @ 2:42 pm
what are your latency settiings set t,o both stream and asio latency?
geposted Sat 03 Oct 09 @ 6:38 am
I´ll post my latency settings tomorrow because i´m currently not at home.
Best regards.
geposted Sun 04 Oct 09 @ 1:34 pm
1.5ms and 3.0ms. I just installed Win7, I might be able to get it down to 1ms/2ms still need to do some testing.
geposted Mon 05 Oct 09 @ 5:12 pm
Wow very good. I never get below 6ms and 8ms. Using Vista Home.
geposted Tue 06 Oct 09 @ 2:48 pm
thanks for posting your settings got em down. how do i map the midi knobs of the zero4 to do different things on eachdecks i.e. i want a knob to control the second effects knob in vdj on both decks but it only will map to one deck not both. how do i specify which deck to map to?
.....nevermind figured it out
deck 1 effect slider 2
deck 2 effect slider 2
geposted Thu 08 Oct 09 @ 10:41 am
I have my Korg Zero 4 in the flightcase. Getting it in there was a bi**h because the mixer is Looooong. I had to buy right angle xlr cables and cut some of the foam out just to get it to fit in.
I have not attempted to do anything with this mixer yet besides use it as a normal mixer.
I kinda like it but the headphone volume SUCKS REAL BAD!!! Maybe i'm just spoiled by my Tascam X-9 or maybe i'm just getting old and i'm resistant to change. Anyway, i'll be loading the drivers soon and attempting to use the Korg soundcard instead of my external one.
Can I use ch 2 and 3 for timecode with the Korg Zero 4 soundcard? I really like having my ch faders aligned with my cross fader.
geposted Sat 17 Oct 09 @ 2:39 pm
yes adn you can assing ch 1 and ch4 for midi controls
geposted Mon 19 Oct 09 @ 3:30 am
CH 1 and CH2 are only supported for timecode inputs. I think this is a limitation with VDJ.
thanks,
David
thanks,
David
geposted Tue 20 Oct 09 @ 5:52 pm
thanks,
David
thanks,
David
I thought you can map any input to any output in the korg software
geposted Wed 21 Oct 09 @ 2:05 am
You can use Timecodes on Ch 1 & 2 but as noted above, get the Traktor patch to enable the mixer to use the time codes properly.
The headphone volume does suck. some people have reported that updating to the latest firmware fixed that issue, but it didn't for me. I have been using an external inline headphone amp to make it loud enough. I also have been using the Korg's firewire sound card with no problems at all.
geposted Wed 21 Oct 09 @ 2:21 am
I have my gain set to 3 o'clock. That is the only way to get a sound up loud enough in the headphones ans master out.
-David
-David
geposted Wed 21 Oct 09 @ 7:54 pm
am pretty new to the digital world. can any one tell me what my sound set up should look like when configuring virtual Dj to my KORG Zero 8?
geposted Tue 12 Jan 10 @ 8:02 pm
Should be the same as the Zero4, but with 4 more channels. This is my config on the mixer with CDJ's. For Vinyl dont use the tracktor adapter: http://www.virtualdj.com/forums/111258/Hardware_Technical_Support/Korg_Zero_4_TimeCode_Help_.html
In VDJ have the slider 1 notch over from the left, latency set to auto, safe mode /overclock unchecked, scratch set to latency.
ASIO settings for Zero4/8 driver set to 1.5/3ms.
thanks,
David
thanks,
David
geposted Wed 13 Jan 10 @ 10:47 am
does the VDJ pro software give you the ability to utilize more than 2 channels when mixing?
geposted Tue 24 Aug 10 @ 6:32 am
I think when Virtual DJ 7 is released, you should be able to utilize all 4 channels:
http://www.skratchworx.com/news3/comments.php?id=1525
thanks,
David
thanks,
David
geposted Tue 24 Aug 10 @ 10:52 am
