Forum: MAC Version Technical Support - Topic: Install Error Need Immediate Help
Discussions about the Mac version of VirtualDJ, Numark Cue or Virtual Vinyl. Also, general Mac discussions and hardware use are welcome. Before posting, please read the FAQ.
If you are experiencing technical issues or protection errors please contact Service Support.
VirtualDJ Forum
MAC Version Technical...
Install Error...
Autor - Topic: Install Error Need Immediate Help -
NortheastDJs
Professional edition user
Posted Thu 01 Oct 09 @ 6:41 am
I purchased a copy of Numark Cue for windows and installed it on my laptop. I updated to version 6.02 to find out that my laptop was unable to handle the load placed on it after syncing midi to my Denon S3700s.
I registered my copy of Cue so I could download 6.02 for my mac and tried it on my iMac which is running Leopard. It works beautifully. However, it's not realistic to drag my 24" iMac to shows.
Last night, I went out and purchased a new MacBook Pro and plan on turning this into my gig computer. This system has Mac OX 10.6 on it. I started with version 5 on my MacBook Pro and then tried to update to version 6.02 (The same way I did for my iMac). When I try to install the update this is the message I get:
"There were errors with the installation. You may want to try installing again." "The installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance."
I have tried installing it a few different times and came up with the same problem. I have a show this weekend and no computer to run my show off of.
Immediate help needed!
ReThink
Posted Wed 28 Oct 09 @ 7:02 pm
Im not sure how the software would know but I am positive that you are only allowed to install the software on 2 different machines. I dont remember the wording exactly but...its in the EULA.
Anyone else have any input?
DJ Cyder
Atomix Productions
Posted Fri 30 Oct 09 @ 1:48 pm
update to 10.6.1 and try again.
lopez453
VIP Member
Posted Thu 05 Nov 09 @ 2:58 pm
Any luck ?
yeasterday my friend had same problem with virtual vinyl while trying to upgrade from 5.2.1 to 6.0.2 with same message under snow leopard.
But I forgot to check if he has latest snow leopard.
I'm doing a clean reinstall of my macbook pro and will try vdj 6.0.2, it should be same.
