hi all,
numark announced the new NSFX hardware controller.
http://www.numark.com/nsfx
will this controller be supported bij vdj, and if so, when.
tnx
tnx
geposted Mon 05 Oct 09 @ 8:57 am
without serato itch that controller does nothing
geposted Mon 05 Oct 09 @ 6:33 pm
Its midi you can map it in about 2 minutes.
geposted Tue 06 Oct 09 @ 4:14 am
Thats what they said about the NS7...
We see how good that has turned out so far. I know it will be resolved at some point in the near or far future.
Hey Skyfxl,
How's the move to the states coming?
Hey Skyfxl,
geposted Tue 06 Oct 09 @ 11:41 am
exactly why i asked this question, i remember simular remarks for the ns7 itself, and that still don't work well.
has there been actual tests done wilth the nsfx and vdj
geposted Tue 06 Oct 09 @ 2:18 pm
DO NOT QUOTE the thread right before your own ... it just makes the thread look like crap.
Since VirtualDJ now supports MIDI and HID devices and since this device is MIDI then the device will be supportable - just like the NS7.
geposted Tue 06 Oct 09 @ 4:19 pm
djcity wrote :
Hey Skyfxl,
Hey Skyfxl,
Complicated, had to fill in allot of paperwork, waiting response from Immigration at the moment.
geposted Wed 07 Oct 09 @ 11:50 am
Is there a link that describes the mapping process in detail?
Ive never mapped MIDI before and would like to get the NSFX.
Ive got the NS7 working great with Vista 64 bit but would like to get control of effects and samples off the computer and on the controller.
Thanx
geposted Wed 13 Jan 10 @ 6:23 am
Yes, VDJscript mapping is described in detail on the following page:
https://virtualdj.com/wiki/VDJscript.html
geposted Wed 13 Jan 10 @ 12:18 pm
Thanx>
That was easy as hell!!!!
geposted Wed 13 Jan 10 @ 4:27 pm
I JSUT received the NSFX & can't wait to play with it!!!!!!
I went to the page that gives you the instruction to map it but its not very easy to do. Can someone just simplify the instructions to say cut/copy and paste, or can VDJ update the program that includes the mappings to the NSFX?
I guess I have to wait to play with the NSFX :-(
Thanks,
Thanks,
geposted Tue 18 May 10 @ 1:36 pm
And you dig up a thread that is old when the answer to your question is only 3 threads down - https://virtualdj.com/forums/123109/Hardware_Technical_Support/NSFX_Def___Mapper.html
geposted Tue 18 May 10 @ 2:03 pm
