I intend to run Virtual DJ on a laptop that only has one audio output. Which is the best USB sound card to use so I can listen each each song I load for mixing indpendently like I would on a mixer with two turntables(headphone cueing) and how do I configure this. I looked at the Maya44, is that a good choice?
geposted Tue 26 Apr 05 @ 12:06 am
you need the full version of virtual dj for that
geposted Tue 26 Apr 05 @ 12:08 am
Ok. but what is your recommendation on an external USB card that will aloww me to do that and is the setting changed in the config?
geposted Tue 26 Apr 05 @ 12:11 am
maya 44 is very good and works ok
geposted Tue 26 Apr 05 @ 12:32 am
I would recommend the Maya 44 USB. I use it regularly. All the config setups, just search the forum. It's well documented. You can do the the split thing with the full version. Just buy one from Radio Shack if you're in the US. Good luck. The program is great.
