I normally use one cue but did multiple cues but for some reason i cannot remove them, surely there is a way?
Any pointers?I did a search and nadda.
geposted Fri 09 Oct 09 @ 5:35 pm
Should be able to right mouse button click on them to remove them.
geposted Fri 09 Oct 09 @ 5:41 pm
No that dont seem to work, how strange.
geposted Fri 09 Oct 09 @ 7:01 pm
My guess is that you're trying to delete from the wrong window/area. You have rt.click -> delete from within the tine-weeny-intsy-bitsy waveform window (small one that show the entire track, in each player), not the larger, more intuitive Rhythm window (Top Center). See tech manual page 23 for close-up. (though it doesn't show any que points) When you hover over a cue point, indicated by a small white line, it will turn green. When green, right click, select delete. If you have many cue points close to each other, good luck selecting the right one.
https://virtualdj.com/forums/113693/PC_Version_Technical_Support/Deleting_Cue_Points.html
geposted Mon 12 Oct 09 @ 10:31 am
You can also map keyboard shortcuts or buttons on MIDI controllers to delete cue points, e.g:
delete_cue 1
(Deletes cue point #1 when pressed.)
delete_cue 1
geposted Tue 13 Oct 09 @ 12:54 pm
