| Autor | - Topic: How to save Cue points! - |
Hi, Can anyone explain to me how save a cue point so that remains even after I've closed virtualDJ and opened it again? Thanks Xavier |
as long as u shut down vdj properly it should be saved next time u load it as long as the file is from the same location it was when u added the cuepoints |
I'm having the same problem. Closing the app using Apple Q... Also all of my DB info (BPM n such) goes away as well. I am guessing I am doing something wrong or have not configured the DB properly. I imagine Xavier is having these problems as well. Been reviewing the manual to no avail. |
Pls continue here.. http://www.virtualdj.com/forums/117426/MAC_Version_Technical_Support/How_to_save_Cue_points____SOLVED_.html It is not necessary to have same thread on different forum. It will create confusion;) Thread Lock. |
