Topic: VDJ DATABASE UPDATER
hi dj in norway
ive read your post about using mimeister and database updater, procedure no 1 is ok ive done it i export it in txt file and i save it in one folder, but how about procedure no 2,3,4 and 5 if it is ok for you will you please explain to me in more specefic way the other remaining procedure....
thank you very much for your kindness......
1) Run the MixMeister tool, and export the results to .txt file;
2) Load the database updater program
3) Enter the path to the MixMeister file (box 1), and the path to VirtualDJ's database (box 2);
4) Enter a new file name (3rd box) for the new database (the updated one);
5) Click on the 1st button ("Update Database").(This WILL NOT overwrite your current database)6) If you want to automatically 'overwrite' the database, click on the button ("Backup and replace Database"), which will create a backup of your current database, and it will replace the database with the new one.
geposted Thu 28 Apr 05 @ 11:02 am
i have a big problem,
i have bought virtual dj v3,4 a long time ago, but i can´t find the series nummber (key) from it, can sombody help me?!
all you have to do is contact support...no one on these forums can help you with a lost serial, only support can do that...also next time please try to stay on topic or near it
it is not te good topic. Thanks not to pollute this current topic with other question.
