Hey, my stanton scs3 system arrived in the post about a week ago but I've been on the search for a program to use with it, I remember virtual dj supporting two different soundcards when using it in college last year and the tracktor that ships with it doesn;t, which means its useless as I can't cue.
I plan on downloading the demo verison of VDJ6 once I get my laptop back, just wondering what is the functionality like?
Is there anything I need to know what to do in VDJ before I use it, or can I just plug in the SCS3 and install VDJ and go?
Also if this does work fine and I order the full version after the trial peroid is finished, will I get future version updates, like if there was a 6.0.3 and so on?
Sorry for all the questions guys.
Thanks, Scott.
Thanks, Scott.
geposted Sat 17 Oct 09 @ 2:15 pm
You didn't see this thread -
https://virtualdj.com/forums/116980/Hardware_Technical_Support/STANTON_Hardware_Products_(Setup__Solutions__Fixes__Issues__etc_).html
or this one
https://virtualdj.com/forums/115754/Hardware_Technical_Support/Stanton_DaScratch_Mapping_files.html
You had to start a whole new thread ?
And as for future updates - yes, with a licensed version you will get updates.
or this one
geposted Sat 17 Oct 09 @ 2:51 pm
