Hi,
I'm noticing under the new mapper in VDJ 6, my EKS XP10 controller is not working properly. Specifically, the scratch function.
In VDJ 5:
Top platter: Touch it, it pauses, move your finger on it, it scratches
In VDJ 6:
Top platter: Touch it, it pauses, move your finger on it, it sometimes scratches, but often "jogs" (slightly speeds up or slows down the track)
Anyone else having this problem? It used to work GREAT before in VDJ 5. :( I'm totally bummed.
-Josh
In VDJ 5:
In VDJ 6:
-Josh
geposted Mon 19 Oct 09 @ 10:27 pm
look in the Config on the Options tab there you can adjust the scratch sensivity ? perhaps this helps ?
geposted Tue 20 Oct 09 @ 6:16 am
Are you running the latest v6.0.2 version of VirtualDJ?
https://virtualdj.com/download/updates.html
geposted Tue 20 Oct 09 @ 1:53 pm
YES! Fixed it...thanks man.
(I was reluctant to update because I have a gig in a few days, but you saved me.)
CHEERS!
CHEERS!
geposted Sat 24 Oct 09 @ 9:04 pm
