sorry but i don't know if its possible.... if i buy the pro version, can i use VDJPRO stand alone or with another midi like the vci-100 although i got that discount form the rmx?...more clear... can i use the pro version without the use of rmx. I ask this, since you cant use the limited edition stand alonne (without the rmx).
thanks
thanks
geposted Thu 22 Oct 09 @ 8:58 pm
The pro version has a skin called vdj MAC internal mixer. I can get it to work, but I have to reselect the sound card in the sound setup tab. Big advantage to the pro version is you get more skins.
geposted Fri 23 Oct 09 @ 12:44 am
thanks
thanks
It works with just about any controller, or none at all(just your mouse and keys. The discount you got was for upgrading from the limited ver, to an unlimited one. All you have to do is set up the midi controller in the mappers window, and chose a sound output. Not sure if you will need to install any drivers or not.
That's one thing I love about VDJ6 pro. You can even use timecode if you want to.
geposted Sat 24 Oct 09 @ 4:01 am
Seriously, these repeated double-posts of yours are really starting to piss me off.
https://virtualdj.com/forums/117689/General_Discussion/vdj_stand_alone.html
Are you too stubborn or thick to understand, or do you just think you're such a important guy that rules of a good forum conduct don't apply to you?
geposted Sat 24 Oct 09 @ 4:42 am
like my lawyer says
no further questions.... and thanks for the advise.
AuralCAndy... Im an important guy as you are...
thanks for tracking my topics, but i wouldn't spend time doing that... no hard-feelings
i'm searching for answers in order to cover my interests, sorry if the method is not the correct, i relative new here and i will take you advises in the good way.
Regards
Regards
geposted Sat 24 Oct 09 @ 12:11 pm
That's just the issue here...I don't have to spend time tracking your topics, quite the opposite - you're practically drowning us with your threads.
geposted Sun 25 Oct 09 @ 8:35 am
sorry
geposted Mon 26 Oct 09 @ 5:52 pm
