hello just a basic question ... i noticed after i download a skin and apply it, i cant find a config button ? Does anyone know where or how to bring it up to change the skin agian ?
geposted Sun 01 May 05 @ 4:20 pm
anyone ? i mean does anyone know the key setting for config atleast, if there is one ?
geposted Mon 02 May 05 @ 12:48 am
what skin did you download??
geposted Mon 02 May 05 @ 7:31 am
i mean i cant find it on any other skin except the default ones ? for example how about:
ATOMIX-FR 1[1].1.zip
geposted Mon 02 May 05 @ 9:39 am
Well these buttons are on all skins, and are usually placed by other buttons (music, search, effects, samples, ...). On default skin it's placed on the top-right corner, that's why you probably got confused.
geposted Mon 02 May 05 @ 7:06 pm
the conf button is sometimes labeled as Set or menu in other skins
geposted Tue 03 May 05 @ 9:32 am
