hey all
i got virtual dj pro and cant use new skin keep telling me [the compressed file is invalid or corrupted]
can somebody help me
thx
thx
geposted Mon 02 May 05 @ 3:07 am
Make sure there is an extesion to the filename. .zip (I think)
geposted Mon 02 May 05 @ 5:13 am
With a few explorers you must manually rename the downloaded file as a .zip.
If VDJ doesn't start correctly and you get an error message telling you that your skin file is corrupted than:
- Delete your skin and start VDJ without it.
- Close VDJ.
- Download again your prefered skin and move it into your VDJ root directory.
- Start VDJ again.
Tell us if you still have a problem (also tell us if it is corrected; this way other users will know about how to proceed).
Regards,
Clax
- Close VDJ.
- Start VDJ again.
Regards,
Clax
geposted Tue 03 May 05 @ 11:47 pm
I want a New Skin
geposted Fri 01 Jul 05 @ 8:05 am
Hi Daneel;
To request a skin you have to write more details. What do you want exactly ?
Creating a skin is really a big work and it takes a lot of time to the designers.
You have better chance to have you wish realised if you are a full user. So if you like this software I suggest you to get the full version ; this will help developpers to make it better and better.
Clax
Clax
geposted Fri 01 Jul 05 @ 10:32 am
