Colleagues in general. share what was said that the real dj out his night with the tools you have at that time, demonstrating creativity and consistency in the animate to put his people is based on the knowledge and the variety of music that used to cause euphoria of the viewer. The team is supplemented to enhance the surprise of those around you by showing that each of the tools that are maximized equipment like an editing studio where he made no errors. A hug and continue with the momentum of innovation that somehow be reflected in its economic achievements. For my part I commented that I am trying to find a way to have the headphones prescucha in a VCI-300 with vdj mapper which is the only tool on the page and that VISTA does not bring it on MAC if it works. If someone could guide me appreciate it.
geposted Mon 02 Nov 09 @ 10:26 am
It is a limitation of the drivers published by Vestax trying to limit you into using ITCH ... we currently do not have a solution - yet - to this issue.
geposted Thu 05 Nov 09 @ 4:52 pm
Hi cstoll
Thanks for the info on the Vestax 300
Is there a limitation on the M-Audio xponant using it with VDJ?
Thank you
Joey.....
Thank you
Joey.....
geposted Fri 06 Nov 09 @ 2:51 pm
I previuosly had the trail version of VDJ it worked perfect with my VCI-300... now I started using the full version of the software the mapping is off, i cant scratch, Led doesnt light is dim so in other words it doesnt work except the play button ...any suggestions?? Thanks alot in advance
geposted Fri 05 Feb 10 @ 11:33 am
Please register your purchase http://www.virtualdj.com/users/edit.html and then download the latest v6.0.5 version: http://www.virtualdj.com/download/updates.html
if you are using an older and/or illegal version, then it will not work correctly.
geposted Fri 05 Feb 10 @ 1:27 pm
