Or an effect that is the exact opposite of a long brake? I tried looking around and cannot find anything. Does it exist?
geposted Mon 02 Nov 09 @ 11:40 am
Hi maybe this helps?
Regards;)
Regards;)
geposted Mon 02 Nov 09 @ 1:07 pm
You can also set pitch range 100% , and set pitch to -100% where song stops. Then when you slide the pitch back to 0% you'll hear the effect you want.
geposted Tue 03 Nov 09 @ 1:06 pm
