Alo alo,
I just upgraded to Virtual DJ 6.
Unfortunately, not everything is working right.
How do I fix this ASIO error message?
In addition, when disconnected from the hardware, the Virtual DJ does not playback songs (the play button is pressed in, but the vinyl icon doesn't spin and no sound comes out).
I'd appreciate anyone's help.
Cheers,
Tom
Cheers,
Tom
geposted Mon 02 Nov 09 @ 4:25 pm
Hey Tom,
if you disconnect your RMX from your PC/Notebook, VDJ can't find your soundcard and show up an error.
You had to change the soundcard settings to your build in soundcard, then the trouble is gone.
Haui
Haui
geposted Tue 03 Nov 09 @ 3:57 am
Agree with Haui...
VDJ won't function without soundcard being detected.
Again choose 1st your system's soundcard, being the Primary Sound Driver with Simple output, Apply.
Test functionality of the software. If it moves / play / with sound then your ok, those without 1st the RMX connected.
Now close your VDJ, connect your RMX, go to sound set-up, choose your outputs, choose you sound card (in your case ASIO), then choose the RMX Asio, Apply.
If everything is normal, you won't get error the moment you click apply, otherwise you need to have the latest driver of your RMX.
Now test the software with your RMX.
Cheers
Cheers
geposted Tue 03 Nov 09 @ 7:57 am
Cheers.
Got it working.
Got it working.
geposted Tue 03 Nov 09 @ 1:38 pm
ok i have a similar problem, i got it working(vci300) using the asio 2.9 drivers, but now my sound is distorted, seem like levels are too high, what should i do
geposted Tue 03 Nov 09 @ 11:33 pm
Hey shortysmooth,
have a look to this blog from cioce! ;-)
http://www.virtualdj.com/homepage/cioce/blogs/3832/_ENG__Vestax_VCI-300_audio_setup_on_Virtual_DJ_6_0_2.html
Haui
Haui
geposted Wed 04 Nov 09 @ 9:30 am
Hello everyone,
I have a problem with the same message: Error in ASIO sound driver. I usually work with Traktor 3 and I just bought the Hercules DJ Console RMX and it comes with Virtual DJ, now I settep up the drivers for the Hercules and the Virtual DJ on my laptop and they work fine (Hercules, Virtula DJ and Traktor once I switch to asio in the control panel). The problem comes when I try to do the same on my PC wich technically is faster, more RAM, etc, etc., there I keep getting the error msg when starting Virtual DJ and everything works but the music won't play or sound and the same thing when i switch to SIO and run Traktor there nothing won't even move unless I turn to my PC sound card?s drivers and then everything works but the sound again. I already downloades all the new drivers for Hercules, Traktor, asiofor all, etc, etc. Any ideas?
geposted Tue 10 Nov 09 @ 9:58 am
Sorry, but this seems to be a very special problem with your Home PC. Not shure if we can help...
Do you use the same external Soundcard as for your Notebook ? When you use your internal - maybe it's not compatible with the ASIO4All drivers. Test it with your external or try to get an ASIO driver of the cards manufacturer.
ASIO4All is just a tool that 'tries' to give normal soundcards an ASIO interface. In many cases this is ok, in some not.
Greets, Heiko
Greets, Heiko
geposted Wed 11 Nov 09 @ 3:32 am
Hy!
I use VDJ with BCD 3000 and the ASIO sound driver has stopped every moment and I have to activate it again. However when I activate it, it has stopped again and no music. What is the problem?
Thanks,
Erik
Thanks,
Erik
geposted Thu 12 Nov 09 @ 2:27 am
Having an issue using VDJ And Herc. RMX. I have updated all my drivers for my PC and the RMX. Running the latest version of VDJ (the basic version that came with the RMX. The problem was originaly a cracking static sound, so I updated my PC audio driver, and now I get the ASIO error message. Running Win.7, recently updated chipset and BIOS as well.
geposted Tue 30 Mar 10 @ 4:36 pm
Hello I'm also having trouble connecting My Numark CDX turntabes to Virtual DJ. I have a Numark Mixer with a Gigaport HD esi. Hook it up all im getting is an error message. Newbie please help.
geposted Sat 08 Jan 11 @ 4:01 pm
The Gigaport is unsuitable for timecode use because it has 8 outputs (4 stereo) only instead of the required 4 inputs (2 stereo) and 4 outputs. There are no inputs for the timecode signal.
To use timecode, you will need the full VirtualDJ Pro http://www.virtualdj.com/buy/index.html with a suitable card such as Hercules DJ Trim, Native Instruments Audio 4 DJ, ESI Maya44 USB, etc.
geposted Sat 08 Jan 11 @ 4:27 pm
Haui70 wrote :
Hey Tom,
Haui
Haui
Hi, I need you help, I would like to know how can I set up asio sound card? Sound from VDJ is not being transferred to the speakers. Should I need the latest version of asio? Which would be the latest version of asio drivers? Please help!!!
geposted Sun 05 Jan 14 @ 9:26 pm
melvin… what are you using vdj with??
this is an old thread, u should of started up a new one, but oh well
geposted Mon 06 Jan 14 @ 4:08 am
The ASIO driver is supplied by the manufacturer of whichever audio interface you're using, and is specific to that device.
You cannot use the ASIO driver from another product. They are not generic.
ASIO4ALL is not an ASIO driver.
What audio interface (or controller) do you have?
geposted Mon 06 Jan 14 @ 9:45 am
Hi guys, I bought the DJ Wego last year in March and had no problems with it until last month it started giving me the dreaded "Error in the Asio Sound Driver" and now it won't work, I've tried updating the firmware, uninstalling and reinstalling the program (VDJ LE7) and controller and nothing seems to be working, any ideas on what might be the problem or how to fix it? Thanks
geposted Tue 07 Jan 14 @ 6:36 am
