Hi i just downloaded the pioneer cdj 1000 skin for virtual vinyl but dont know how to apply it to the system. Doe any1 know how to get it running??
geposted Thu 05 Nov 09 @ 9:30 am
Hi Where ever you have downloaded the skin copy it into the Skins folder in Vdj open the folder and doulbe click to install, then open up VDJ and go into config go into skins, the skin should be there and click on it. :-)
geposted Thu 05 Nov 09 @ 10:17 am
Yea, you don't need to do this part. Just double click the skin exe and it will put itself into that folder. Then you can delete the exe when installed.
geposted Tue 19 Jan 10 @ 2:25 pm
graciaas
geposted Tue 02 Feb 10 @ 12:12 am
