Forum: Old versions
Topic: Question on Vestax VCI-300
I'm considering purchasing VDJ to use with my Vestax VCI-300.
1) Is the Vestax VCI-300 native meaning do I have to do anything or is it already setup when I purchase the program (not very good with computers)
2) Will this effect the use of my Vestax with Serato Itch or change any of the midi controls with Itch? I love Itch for Audio but want to use Vestax with Video and Virtual DJ
3) Am I able to have both programs on my Lappy or will the Vestax get confused if I have both programs opened?
4) Anyone using the Vestax with VDJ and have any opinions?
geposted Sat 07 Nov 09 @ 1:44 am
yeah i also would like to know....i got a set of vci300 but not sure if it will work witt vdj ?
(im not the best pc guy also)
Have a look also here:) https://virtualdj.com/forums/120331/General_Discussion/Vestax_VCI_300_users___Questions______.html
1)You are already a PRO User and with the latest version you can use the VCI300 out of the box.
OK; maybe some little adjustments, but it works, like DJ in Norway told us;)
2)No, i don't think so!
3)Sure you can have both on your lappy, but to use them at the same time, is not a good idea. I can't believe this works without any trouble.
4)Hehe, click on the link above ;)
I have a VCI300 Dom. Works great with VDJ. I own an RMX also and the VCI is by far superior to the RMX, and I really like my RMX....
hi,
I am looking to upgrade to a vestax vi 300 are they any good?
I have a demo booked for friday but jusdt wanted some feedback
i am using pro vdj6, is there much mapping to be done?
woz
