I accidently pressed something on the keyboard and the scroll bar at the top where the beats etc go passed has zoomed right in and its annoying and hard to read, since this problem occured when i move the crossfader or pretty much press anything when a track is playing it jumps like crazy makin it impossible to mix. very cheesy!
if anyone can help i would really appreciate it
thanks
thanks
geposted Sat 07 Nov 09 @ 2:11 pm
In v6 trial https://virtualdj.com/download/trial.html you can click the [1] [2] [3] boxes to the right-hand side of the wave form to change the zoom level. [2] will reset to the normal.
geposted Sat 07 Nov 09 @ 2:26 pm
its skin V mix 5.4 its not a trial. im sure it was something i pressed on the keyboard m8
geposted Sat 07 Nov 09 @ 2:36 pm
Change it back to the default skin and then click the [2] to reset the zoom, then change back again.
Check your keyboard shortcuts to see if you have any keys assigned to change the zoom.
Also, skins are only available to registered users - If you have a serial number, please register it on the page https://virtualdj.com/users/edit.html to enjoy all the licensed users, including free upgrade to the latest v6.0.2 if you have Pro.
If you are using an illegal version, please support the software and its development by purchasing your own legitimate license: https://virtualdj.com/buy/
If you don't need to use timecode, MIDI controllers, external mixers and full screen video, then VirtualDJ Home Edition for Windows PC is only $49: https://virtualdj.com/products/homeedition.html
geposted Sun 08 Nov 09 @ 3:00 pm
