Hi,
i have the new mac book pro 17" 3.06ghz, Intel core duo, 4 gigs ram, NVidia 9400M, 9600M GT 256,512 latest Mac OS X Snow Leopard (10.6) and recently purchased vdj pro, Loaded 6.03, controller numark omni pro "everything seems to be up", I would like to be in video mode so i can dj only videos, Problem i am having is this, the skin has 3 mode scratch, mixer, video. I play the video (in video skin mode) fine until i go to cue, pause and play on next vid i want to play next (during the pressing of these buttons), i get player and clip freeze (graphics only not sound) but doing the same motions in (mixer mode, scratch mode) no problems with clip or player freeze, What could be happening ?
geposted Tue 10 Nov 09 @ 10:49 pm
a lot of threads about this my friend... i suggest u read some of these:
https://virtualdj.com/forums/118498/MAC_Version_Technical_Support/Mac_improves_and_priorities_for_the_next_release.html
https://virtualdj.com/forums/117375/MAC_Version_Technical_Support/When_is_the_Video_fix_for_6_02_Mac_going_to_be_available__Any_one_heard_anything_.html?page=1
bottom line
theres no solution until apple allow hardware decoding of video.
u have two choices deal with that or use bootcamp.
saludos
bottom line
saludos
geposted Tue 10 Nov 09 @ 11:56 pm
Is anybody successfully running bootcamp w/the same setup i have? if so what OS xp. vista or new ms7? and after installing VDJPro what other things do i have to be do (Thanks In Advance)
geposted Wed 11 Nov 09 @ 11:23 am
