hI :
I have all my hot cue leds in green using my vestax vci300 ... with itch hot cue 1 is red - 2 blue and 3 yellow ... can we do something ?
Man-Tk
Man-Tk
geposted Wed 11 Nov 09 @ 7:26 pm
I'll remake for colors ;)
will upload tomorrow
geposted Wed 11 Nov 09 @ 7:41 pm
Thanks .... It would be good to know how to do it also ....thanks again
geposted Thu 12 Nov 09 @ 3:04 am
This is not a hardware question !
geposted Sun 15 Nov 09 @ 6:20 am
Should be an easy thing. Go to your mapper settings of the vci-300. Enter a action for all the 'GREEN' leds in the list with 'nothing'.
Then select the correct LED (for example in 'BLUE') and enter the correct action for lightning up.
For example:
'hot_cue 1' for the LED in RED.
(Take a look in the List - there are all the VCI Elements, also all the different colors of the leds)
Greets, Heiko
For example:
Greets, Heiko
geposted Sun 15 Nov 09 @ 10:18 am
Ok ...done ...thanks
geposted Mon 16 Nov 09 @ 1:29 pm
Did it work like you wanted it ?
Greets, Heiko
Greets, Heiko
geposted Mon 16 Nov 09 @ 2:47 pm
Yes I saw him post it on spanish forum that he could map as he want, thanks Heiko ;-) I'm sure he is going to tell here by himself, just want you to know.
geposted Tue 17 Nov 09 @ 12:50 am
Greets, Heiko
Greets, Heiko
Yes , thanks ...all is OK now ...
BTW : I don't know who moves this post to here ...because this is not a hardware issue -
geposted Tue 17 Nov 09 @ 7:15 am
It's an hardware discussion and general forum it's like a recycle bin sometimes, just to clean some topics...
Anyway your mapper is now available ;)
https://virtualdj.com/addons/9700/Vestax_VCI-300_with_correct_LED_mapper.html
geposted Tue 17 Nov 09 @ 7:38 am
Dont know who moved it, but isnt a VCI300 a piece of hardware?? And u were askin questions about it??? I dunno:)
geposted Wed 18 Nov 09 @ 4:28 am
right it fits here cause i wouldnt of found it anywhere else following that same logic as above
geposted Fri 20 Nov 09 @ 12:10 pm
the mapper fixes the led's but breaks the crossfader lol, I'll upload a better one later.
geposted Fri 20 Nov 09 @ 9:34 pm
The crossfader is disabled . Sorry .
geposted Sat 21 Nov 09 @ 3:36 am
VDJ can disable the crossfader without to delete from mapper, just in case you don't know...
geposted Sat 21 Nov 09 @ 7:38 am
I have the crossfader for video . not audio ...thanks
geposted Sat 21 Nov 09 @ 8:40 am
You can also do that without modifying a mapper - Set Options -> Crossfader to Disabled and tick Video -> Video crossfader linked to audio. Now the crossfader will act as a video crossfader only.
geposted Sat 21 Nov 09 @ 2:09 pm
