I changed my shortcuts so that I could use the up and down arrow for pitch. But now I cant scroll up and down my songs list. There seems to be no shortcut option for this am I missing something?
geposted Mon 11 Aug 03 @ 4:07 pm
also I tried using the search function instead and creating a shortcut that would jump to that page but there is no shortcut to jump into the text box.
Thankyou
Thankyou
geposted Mon 11 Aug 03 @ 4:12 pm
The list navigation shortcuts can't be changed.
The up, down, home, end, ctrl+A, ctrl+arrow, shift+arrow, enter, and so on, can't be changed.
If you assign another shortcut on this keys, then you can't use it in the list.
About the search, there do is a "search" action in the shortcut list that will bring you on the search page, focused on the search field.
geposted Mon 11 Aug 03 @ 4:40 pm
I cant edit effect_button.
Please write the xml code
geposted Tue 02 Sep 03 @ 6:50 pm
