Finally got my second ground loop isolator. Radio shack was out of them.
My question is where do i plug them in, seems im gonna need a female to go into the male or vice versa..
Do i go straight from my mixer to the sound card, turntalbe to soundcard?
I do have the faint sound of the TCV whistle coming from my system when I have nothing playing... or when a song reduces to almost no sound..-- very evident-
Do u guys think this will reduce that noise. or does everyone have the same whistle sound?
Thanks!!
Thanks!!
geposted Thu 05 May 05 @ 5:06 pm
Go from the Sound Card outputs to the Line Inputs of your mixer - this is where the isolation usually needs to take place.
This is the configuration I use and I have never had the whistle sound from the TTs.
cstoll
cstoll
geposted Thu 05 May 05 @ 8:01 pm
thanks.. ill get on it tonight.
appreciate the kind info.
geposted Thu 05 May 05 @ 8:11 pm
you may find the whistle noise stays, but not through your speakers, it's actually coming from the deck itself. play a record with a lot of hihats, turn your speakers down, and you'll most likely hear it coming from that too
geposted Mon 09 May 05 @ 6:37 pm
well installed the ground loop isolators... Happy to report no buzz, no whistle, no hum- just clear music- thanks cstoll!!! u da man!
geposted Mon 09 May 05 @ 8:48 pm
no problem, dirty little trick an old school sound engineer taught me.
I don't do any gig without a couple different methods at my disposal for out-of-phase / grounding issues.
glad it helped!
cstoll
glad it helped!
cstoll
geposted Tue 10 May 05 @ 3:00 am
I know that this is an old topic, however, I was wondering whether you, Kiteman, had any signal before getting the ground loop isolators? I can't seem to get a signal at all. My setup is described in the link below. I'll try the suggested placement of the isolators; I was using them between the phono output of the TT and the Y splitters I was using to split to the Phono inputs of the mixer and the analog inputs of the Maya. So, if I understand correctly, I need to move that to the output from the maya to the line input of the mixer? Thanks in advance.
https://virtualdj.com/forum/display.html?topic=13509
geposted Wed 22 Jun 05 @ 4:35 am
"So, if I understand correctly, I need to move that to the output from the maya to the line input of the mixer?"
Yes, you understood correctly. If you connect them between TTs and Maya you'll never got full signal because GLI cut frequences of TC signal.
Dj Nikki
Dj Nikki
geposted Wed 22 Jun 05 @ 12:23 pm
So the same with Y splitters, if you have bad TC signal try to connect the turntables directly to the maya without the splitters.
geposted Wed 22 Jun 05 @ 1:20 pm
i recently bought a AV 710 soundcard (http://www.newegg.com/Product/Product.asp?Item=N82E16829120103) and im really confused about how to make it work with my Virtual DJ can u pls help me
geposted Wed 30 Nov 05 @ 4:09 am
