Hi there
i would like to know who to mapp vdj 6 to get the same feature with dn s1200 (dry/wet) in mode usb/cd with the jog wheel.
i don't know anything of mapping.
thanks
Dan
thanks
Dan
geposted Wed 25 Nov 09 @ 8:18 am
Please see https://virtualdj.com/homepage/jpboggis/blogs/3702/VDJscript_examples.html for various VDJscript examples, including how to adjust FX parameter using the jogwheel when the effect is active.
geposted Wed 25 Nov 09 @ 12:26 pm
Thanks for your answer
but.. I've tried to change the parameters in config/mappers.
changed values on jog / jog_touch / jog mode.. but everything runs as before
please could you let me know something more about this
thanks
Dan
thanks
Dan
geposted Thu 26 Nov 09 @ 2:48 am
oops
Sorry i already did it, just the filter effect can't be adjusted by the jog wheel because has no delay as flanger.
any idea for the filter effect with delay...
thanks again
Dan
thanks again
Dan
geposted Thu 26 Nov 09 @ 3:00 am
Unfortunately TK Filter and Beatgrid effects don't support MIDI mapping - They were created when MIDI controllers were not very common and use a custom graphical interface that is only compatible with the mouse.
Only effects that have a slider or have been written to act on the effect slider command can be adjusted via MIDI.
geposted Thu 26 Nov 09 @ 12:30 pm
