Hi all, just to inform there is a new release now available.
VirtualDJ 6.0.4 (29 November 2009)
optimized netsearch video
fixed cover downloading from amazon
fixed cover downloading from google
fixed cover downloading from youtube
optimized speed of cover downloading
optimized pitch in timecode smart mode
new timecode noisemap engine (serato "beta engine")
fixed timecode virtualdj old engine "v4"
fixed timecode clearsound with relative mode
fixed clone_deck
updated timecode configuration wiki
search transliteration for hebrew
fixed search shortcut character in searchbox
new actions: clear_search, edit_search
fixed F10 shortcut
fixed action browser_sort
new registry setting MaxFiledateSort
added controllers: RADIUS1000, RADIUS3000, DP2, ME100
fixed controllers: ME701SC, CDJ900, DIGITALJOCKEY
https://virtualdj.com/wiki/VirtualDJv6.0.4.html
Regards;)
fixed clone_deck
fixed F10 shortcut
Regards;)
geposted Sun 29 Nov 09 @ 8:55 pm
i cant believe my eyes another update :) well done, really, its so good to have regular updates.
My VDJ now longer crashes when closing the program, plus i see more controller support. Nice one VDJ, Keep it up and you will get nothing but good feedback form me..
geposted Mon 30 Nov 09 @ 2:14 pm
will this run on tiger?
geposted Tue 01 Dec 09 @ 1:06 am
I have a problem, but i can´t reproduce and help now.
In German Forum are Users, they have a Problem with stuttering wavelines.
with 6.0.3 it was less. What is the solution?
And I have a positive message:
TC works with Hercules DJ Console MK2 (SK)
BUT the quality with original CD´s (no TCCD) must be very bad.
geposted Tue 01 Dec 09 @ 4:33 pm
6.0.4 with My VCI 300 & macbook pro 2.4 core 2 duo. The sound is alittle louder and distorted. The Headphones dont work properly. I cant cue the songs. The earlier previous version, songs sounded better.
geposted Tue 01 Dec 09 @ 10:23 pm
I have same problem. but i had it in 6.03 too.
even opened a thread on it:
https://virtualdj.com/forums/119653/MAC_Version_Technical_Support/The_%28almost%29_only_issure_left.html
geposted Wed 02 Dec 09 @ 7:25 am
I believe it lies on the memory.
how much memory you have on the macbook?
geposted Thu 03 Dec 09 @ 7:41 am
anyone knows if it works the reloop digital jockey 2
geposted Thu 03 Dec 09 @ 7:43 am
4GB ddr3
geposted Thu 03 Dec 09 @ 9:09 am
Hi everyone,
i've just bought virtual dj 6.04 but it does'nt launch!
Why does it can?
is there somebody have the same problems?
Please Help!
Why does it can?
Please Help!
geposted Sat 05 Dec 09 @ 8:04 am
Are you on Mac OS Tiger?
geposted Sat 05 Dec 09 @ 8:38 am
Anybody experiencing BPM problems?
BPM analyzed for example at 127bom
when the track loads onto a deck it shows as 127.12 for example
I am constantly tweaking the timing of almost every track that loads.
geposted Sat 05 Dec 09 @ 10:38 am
Have you read the first post? DigitalJockey?
geposted Sat 05 Dec 09 @ 4:49 pm
Leopard Snow problem
Everytime i load a track, vdj locks up
anyone have this problem?
geposted Sat 05 Dec 09 @ 10:15 pm
tried setting audio codec to quicktime?
geposted Sun 06 Dec 09 @ 1:28 pm
I ran through 2 gigs this weekend with my Unibody MBP, 2.66Ghz Core2 Duo, 4GB DDR3, VDJ 6.0.4 and SnowLeopard 10.6.2. All-in-all, a much more solid experience running VDJ in native MacOSX. I had been boot-camping up until this point and love the idea of keeping Windows out of the equation.
My only glitch is when using the Denon HS-5500, VDJ will intermittently hang the entire interface and connected USB controllers. Sound continues to play, but all interactivity is lost. Control with the Denon HDC-4500 is flawless.
Thanks for the continued efforts, it's getting much better!
geposted Sun 06 Dec 09 @ 6:49 pm
Still having problems when it comes to looping video on the mac, audio is fine but still lots of gliches on video
geposted Mon 07 Dec 09 @ 7:32 am
1. Second FX (on both decks) still is gone. These were present in 5.x
2. Video crossfades still flicker badly, especially near 50%.
3. ClipBank thumbnails do not work. They get shoved to the left and converted to grayscale.
4. Video crossfades do not function properly between videos and ClipBank. Here you can plainly see that, even though the crossfader is almost faded completely to the left deck, my logo from the right deck via ClipBank is what is being displayed. The crossfade function is broken. Please Atomix, just try this and you will see the problem very easily.
geposted Mon 07 Dec 09 @ 11:14 am
hi i just bought vdj pro (6) but it doesnt launch I have tiger...
geposted Wed 09 Dec 09 @ 5:57 am
Please contact support and ask for special download to v6.02. Regards;)
geposted Wed 09 Dec 09 @ 6:46 am
