Thiis is a very quick one that could easily be implemented in the 6.0.5 release ;-)
As you have to use thr right-click menu to move virtual/filter folders up and down the browser window, it's very frustrating that the "Delete" option is right next to the "Move Up" option.
A new folder is always added to the end of the list and with larger numbers of folders you have to keep moving the folder up to get it to the right place. If, by mistake, you press "Delete" and not "Move Up" you don't even get asked "Are You Sure?" it just dissappears. Do you know how annoying this is??????
All I am asking for it to have a simple message box dialog that asked my is I am sure I want to delete the folder before actually doing it.
Luckily I had not added any files (been here before), but if I had.... Jeeez, that would have been a nightmare!!!!
So please, please, please in 6.0.5 just ask us if we are sure we want any folder deleted before doing so.
Cheers,
Roy
Cheers,
Roy
geposted Fri 04 Dec 09 @ 6:32 am
Agreed, another annoying and dangerous one is the right click option over a browser or folder list, the fist option is Remove, how many times in the heat of the memont I removed songs because it's so easy to make a mistake.
Can you Please make Preview the fist option, that's what I use most often.
Thank You
Joey...
Thank You
Joey...
geposted Sat 05 Dec 09 @ 2:02 pm
+1000
geposted Wed 09 Dec 09 @ 7:27 pm
Would be also cool if you can drag an drop your folders instead of, right click move up, right click move up, right click move up, right click move up, or vice versa you get the picture.
Also very annoying! Just a simple drag and drop to the destination would very much appreciated guys thanks...
geposted Wed 16 Dec 09 @ 11:23 am
@HKNYC
+100000000000000000000000000 OMG AMAZING IDEA!
geposted Thu 17 Dec 09 @ 3:25 pm
It would be enough to have a couple of keyboard shortcut for "move up" "move down" actions...
geposted Sat 19 Dec 09 @ 11:21 pm
+1000..............basically like serato
geposted Sat 19 Dec 09 @ 11:57 pm
That would be a great short term fix until true drag 'n' drop could (maybe) be delivered...
Cheers,
Roy
geposted Mon 21 Dec 09 @ 1:12 pm
how i can delete (unistall) the virtual dj from my mac???
geposted Fri 05 Feb 10 @ 5:37 pm
You need to post this in the Mac support forum, not tail it on to a completely unrelated discussion.
Cheers,
Roy
geposted Mon 08 Feb 10 @ 1:44 pm
