Can you preview samples in the new version? If so this is defenietly the program I need to buy. Let me know :) :) :)
geposted Sat 07 May 05 @ 8:58 pm
you can if you set your samples to go to a different soundcard than your music (advanced soundcard setup), and you have it all connected to an external mixer with prelisten function (cue)
Thats the way I do it :)
geposted Sat 07 May 05 @ 9:00 pm
You can use prelisten monitor too for samples since vdj v2.10
geposted Sat 07 May 05 @ 9:41 pm
thanks for the info guys. So djcel......how would i do that? does that mean there is some sort of setting letting you monitor the samples? would u have to use another channel on the mixer to prelisten to? Please explain.
Thanks again :)
Thanks again :)
geposted Sat 07 May 05 @ 11:22 pm
This is good, but it will be better to have a switch button for samples, like "play on: right deck, left or both"? That way you can use only one card (with 4 channels, 2x stereo), and you can prelisten on your external mixer! And I suggest everyone to use external mixer, it is much better than anything else!
This should go in "new features" forum... :)
geposted Sun 08 May 05 @ 6:46 am
