Forum: Old versions
Topic: WILL THIS WORK WITH VD
i want to buy the scratchmaster 4.0 pack, it contains the gemini xl-300 turntables,,, and i cant quite remeber which mixer. i will also get the maya 44 usb card... i want to be guarnenteed that this will work before i spend all my money on these things. will i have to buy extra wires... if so how much would they be
geposted Sat 07 May 05 @ 9:00 pm
Any turntable will do
All you need is to connect the phono out from your turntable, to the line-in of your maya soundcard.
You would not need any extra wires.. Just phono cables from turntable to maya, and from maya to external mixer
thats it ;)
For even more advanced use, where you switch between regular vinyl use, and timecode vinyl use, you can see a nice picture of "how to" here :
https://virtualdj.com/blog/Dams/blog738.html
do i not have to plug the turntables into the mixer at all. ? what about the ground wires
and the site yu gave me doesnt work...
Sorry.. the blog might be for full users only
But as said, any dj turntable will work...
And Maya 44 usb is a good choice for asio soundcard
wat about the ground wires
