I have tried all of my inputs and outs on my sound card but I still get this error "No timecode signal found"?
geposted Sun 08 May 05 @ 3:23 am
Are you sure you had a virtualdj record playing? what do you see in the black window when you put the config in "advanced" mode? Check on your asio driver and in your windows sound config what input your soundcard is recording (mic, line, cd)?
geposted Sun 08 May 05 @ 3:31 am
The black box is reading timecode quality 0%
I am also using version 2.1..... I have a Audigy2 card.
geposted Sun 08 May 05 @ 3:53 am
I have the same message, BUT for me is really strange.
Because:
1. It works with 100% quality of TC signal
2. Virtual dj record is playing
3. Turntable pitch is in the middle (0%)
I can see the waveform, i work with the same setup and settings for months..
Only the Auto-config button give me this message,
but i can do it manually as always.
(maya44usb, 2x1200's, Vdj vinyls, Stanton 500Al2 carts)
These are at home.
I tried at the club, simillar setup, (maya usb again) and its working there..
And i used my Stanton carts
(Before someone tell me something about the 500AL's)
Is it just a wrong message ?
Because:
These are at home.
geposted Sun 08 May 05 @ 4:04 am
For I cant get no sound what so ever.
geposted Sun 08 May 05 @ 4:11 am
I found the problem and the solution in MY case.
I used Y adapters to connect the turntable outs to both maya inputs and phono inputs on the
mixer. I suspect this made something wrong to the signal. If i connect directly to the Maya inputs the auto config is working. I remember simillar problems with mixvibes Dvs config related to these adapters, therefore i don't recommend them anymore.
Or is it the Gemmini mixer ?
Dev staff, can you test it ?
Anyone else ?
Lack1, your problem is different, you need to check the cables, and soundcard mixer as the message say ..., also check what i wrote earlier (pitch to zero etc.)
Anyone else ?
geposted Sun 08 May 05 @ 4:28 am
lack1, which drivers are you using for your soundcard?
i believe you need the ASIO4ALL drivers to use TCV if you dont have an ASIO compatable soundcard with this version
geposted Sun 08 May 05 @ 4:35 am
I downloaded the asio4 all drivers..........still no sound. I have a Audigy 2 value card.
The tcv are spinning on the turntable. Sometimes I get garble when I plug some head phones. But no sound and when I try the auto config part it says no timecoded signal found, please play a tcv.
One more question....why do they just send the TCV and not one piece of instructions?
geposted Sun 08 May 05 @ 5:17 am
Instructions ....
All you need:
https://virtualdj.com/products/timecode/
All you need:
geposted Sun 08 May 05 @ 5:22 am
Ok let me start from scratch.
geposted Sun 08 May 05 @ 5:30 am
start from "scratch"....hahaha....
Yeah--- make sure you tables are grounded to your computer.
geposted Sun 08 May 05 @ 6:19 am
Ok now I got that fixed but now all I get is humming noise and no music.........
geposted Sun 08 May 05 @ 6:35 am
