Forum: Old versions
Topic: no timecode signal
I have tried all of my inputs and outs on my sound card but I still get this error "No timecode signal found"?
geposted Sun 08 May 05 @ 3:24 am
Maybe you have your inputs muted or unchecked for recording, some drivers sucks
try to be more specific, what soundcard ou have ?
I have a Audigy 2 sound card
are you already in the configuration panel? if so. you might want to try checking the box that says RIAA.
I'm pretty sure that was the problem I had.
Lak1... I may ask, Did you use your Audigy 2 in Low latency mode? more important... It works? Tell my how because I have some days (weeks) trying to make my Audigy 2 ZS to work in low latency mode and I only make it work in VDJ 2.06 in "Remote Control 2" configs. In 2.1 I was unable to make it work at this time. See https://virtualdj.com/forum/display.html?topic=11856
