Forum: Old versions
Topic: help needed!!
I've just got a hercules mk2 off a mate but he lost the cd for it so i downloaded the drivers and that for it off the website
when i first put it on nothing was working then eventually i got it working so it controls everything like its supposed to but when i press play or click play on vdj nothing happens the play icon lights up but it doesn't play
any suggestions?
cheers
anthony
geposted Fri 18 Dec 09 @ 5:41 pm
what set up are you using sounds like your sound set up is wrong
if just using your laptop
inputs... none
outputs...headphones
soundcard...built in(laptops).
ive got the mk2 which overrides the laptop sound car then off that i got headphones and speaker output
i have got it working it was because i had the config wrong but ive sorted it now although i cant listen to the separate decks through the headphone jack on the front face
im gutted at the moment too because i braught some new headphones and i havnt had chance to test them
bump
try make sure you have at headphone output left ..channel/right ...channel 2
nothing is working =/
Which Version of VDJ are you using ? If you own a professional license you should use the actual 6.0.4 or if you use v5 the 5.2.1 or 5.2.2 (RMX).
Greets, Heiko
NOTE: If you are using an illegal version of the software then that will be why you are experiencing problems. If this is the case, please support the software and its development by purchasing it: https://virtualdj.com/buy/ - Also, check your computer for viruses and spyware which often accompany illegal software.
Hello antere07,
Please take the time to describe your configuration.
1) What is your version of VirtualDJ ? Is it VirtualDJ 3.4 DJC or VirtualDJ Pro?
2) What is your computer configuration: laptop or desktop, PC or Mac, CPU model and speed, RAM, operating system?
3) Which version of DJ Console Mk2 driver do you use?
4) If you are in VirtualDJ Pro, what are you audio settings (go to Config > Sound Setup and list the text displayed in the fields
Inputs :
Headphones :
Sound Card :
And is the box "Apply EQ on external inputs" checked?
virtual dj v6.2 professional
laptop pc
ram: 3bg
hard drive: 250gb
OS: vista home premium
intel pentium duel core processor T3400 2.14GHz
Hercules DJ Console Series - 2009_HDJS_4 package drivers
Inputs: none
Outputs: headphones - master: chan 1&2 / headphones chan 3&4
Sound card: asio driver - hercules dj console mk2 asio
box checked on: ultra latency asio
that any help?
There is no version 6.2. If you are using version 6.0.2 - please register and update to the latest version because there are so many improvements since this version.
Actually there is v6.0.5 in your download center.
Greets, Heiko
yer yer thats what it is lol sorry
ill have alook
