yup its in place
runnin windows 7...maybe thats the problem :/
geposted Mon 18 Jan 10 @ 9:23 pm
F0 7E 7F 06 01 F7
this?
im in totally unknown territory [please bare with me]
this?
geposted Mon 18 Jan 10 @ 9:46 pm
it works now thank u!
one more queston, is it normal that when on scratch, the wheel is too "loose"?..i dunno if that make sense dont know how else to describe it
geposted Tue 19 Jan 10 @ 11:21 pm
Does this work for 5.2.1 or just 6.x
geposted Thu 21 Jan 10 @ 8:50 pm
Just go into the options and set the scratch sensitivity.
Also does anyone know how i switch my xfader back to hampster mode, easy in 5.2.1 just have to check invert.. not sure on 6.0.5 can i get some help please?
geposted Thu 21 Jan 10 @ 9:14 pm
If I understand what your're asking then, you can create a keyboard hotkey, mapping it to I think "crossfader_hamster," which puts your crossfader into hamster mode and back normal.
geposted Fri 22 Jan 10 @ 8:58 pm
Im having the same sort of issue. I can map everything but the touchwheels. I want them to scratch. Can anyone help me?
geposted Sat 13 Feb 10 @ 3:07 pm
can somebody please send me the mapper and def file?
geposted Wed 17 Feb 10 @ 2:53 pm
You must be a licensed user to get the definition and mapping files.
Non-Licensed users are not permitted to post email addresses on our forums - email removed in previous post.
geposted Wed 17 Feb 10 @ 4:28 pm
Did you ever get the mapper? please send me at xxx at juno dot com
Edit by Cioce
Edit by Cioce
geposted Fri 26 Feb 10 @ 3:02 am
please can someone send me the mapper, please, thanks
geposted Sun 28 Feb 10 @ 3:10 pm
Sorry, mappers are only available to registered licensed users who have purchased the software: https://virtualdj.com/buy/
If you would like this plugin, then you will need to purchase the software, or wait until a new trial version is released in the future that might include native support for this controller.
geposted Sun 28 Feb 10 @ 3:38 pm
browser knob # 0-CC26 only goes in one direction. how can I make it go up and down?
How do I edit the xml file?
geposted Tue 02 Mar 10 @ 1:45 am
Anyone get the scratch wheel working right? I can mapp, all the sliders and all kobbs minus the LED, and the wheel to search, but no luck yet with, the scratch wheel that sounds good enough to use in live broadcast mixes, and tips on the scratch wheels would be great, is it better, to set the multi funtion button, for Scratch/search ? will this improve the scratch wheel?
geposted Tue 23 Mar 10 @ 12:39 pm
Please use the latest v6.0.7 trial https://virtualdj.com/download/trial.html - It has proper native support for this controller with working LED's.
You can optionally customise it via CONFIG -> Mappers - See https://virtualdj.com/wiki/VDJscript.html
geposted Tue 23 Mar 10 @ 2:50 pm
no luck I installled the trail link you posted, I and it does not see it, Mix Vibes see's it and it will let me kinda map it the simple midi, I can see the mapper if I uncheck the conntected devices, if i select the Ion discovery DJ and click ok still nothing
geposted Tue 23 Mar 10 @ 9:48 pm
No reasons for 2 threads ... continue here -- https://virtualdj.com/forums/116627/Hardware_Technical_Support/DISCOVER_DJ_USB_DJ_controller.html
geposted Tue 23 Mar 10 @ 9:53 pm
