Cut Entry and Exit points are created when swithed to "Automatic Mode" the problem is these points are not always were I want them and Cut off beginning and end of the songs is there any way of altering these points so they coincide with the start or end of a song.
The desired result is to get whole songs to play automatically without loosing intro/outro's.
geposted Tue 10 May 05 @ 8:13 am
turn force fade on, set fade time to 0 should be good to go for simple mix
geposted Tue 10 May 05 @ 8:28 am
Thanks DJ Cyderhouse, works great love this program, and the great international community of users.
geposted Tue 10 May 05 @ 9:35 am
How about if I want to actually MOVE the fade exit and entry points...is that possible?
geposted Thu 23 Jun 05 @ 4:11 am
yes, it is possible by clicking "adjust bpm" buttons on the skin or assigning shortcut to the keyboard.
You can change BMP, phase, and all three types of mixpoints (cut, fade, beatmix)
geposted Thu 23 Jun 05 @ 10:59 am
