Forum: VirtualDJ Skins
Topic: Combined Commandos in Skin XML
Hello,
first time sorry for my worst english.
I want define a button with the Commando
sync & play.
I tried it in the MiniSkin v.09.
I dont need timecode with my eeePC, so i want use this button for the combined Commando
if its possible
THX
here ist my first test, but i didnt work
http://rapidshare.com/files/325518573/Skins.rar
geposted Tue 29 Dec 09 @ 7:04 pm
im not sure if u can do play_sync button but u can do cue_stop or play_pause.
if that combination were possible it would be like play_sync button i think but not sure
DJ ALEX
geposted Tue 29 Dec 09 @ 7:28 pm
djjbPRO InfinityMember since 2004
Hi DJ Lucky Luciano,
I think you can use this:
action="deck 1 sync & play"
good luck
geposted Tue 29 Dec 09 @ 11:24 pm
JeremKPRO InfinityModeratorMember since 2004
Miniskin v0.9 is a VirtualDJ 5 skin.
I don't think that "deck 1 sync & play" will work, but it's worth the try.
geposted Wed 30 Dec 09 @ 7:44 pm
I use this action in my skin: action="sampler volume 100% & sampler loop off & sampler play & nudge -1000ms & play"/> And it works, So I don't see any problem using "sync & play"
geposted Wed 30 Dec 09 @ 11:40 pm
