Hey everyone,
I posted this a few days ago, I could really use some help here. Has anyone used a denon 2600f or 9000 dj controller with VDJ? I read on an earlier post that some is using the denon 1000 controller. Any advise would be appreciated?
Thanks a million,
DJ Yanni
Thanks a million,
DJ Yanni
geposted Tue 10 May 05 @ 5:07 pm
i'm sure either should work fine.
geposted Tue 10 May 05 @ 5:43 pm
I used a Denon DN2500F with the time coded cds. This works ok for Play, Cue, Loop, Pitch bend and Pitch. Some other functions do not work (which is likely): Next track, effects and memo points.
So your 2600 will work, while this is a newer model of the 2500.
Setting cue points is quite hard, while the Denon player will play a part of the song repeatately when you set a cue point. During this process VDJ get lost. Maybe this is improved in the later versions
The 9000 will probably work better, while this product is using vinyl emulation more than the 2500 / 2600.
If you have other questions please ask
Ewout
Ewout
geposted Tue 10 May 05 @ 7:04 pm
