Forum: Old versions
Topic: Vinyl Ripper problem
Have just bought v2.1.
When I launch Vinyl Ripper, I get the error "Impossible to find LAME encoder DLL".
Any help would be appreciated. :)
geposted Tue 10 May 05 @ 5:08 pm
You need the decoder, just google for it, and put it in the folder it will be zipped.
I think the latest is 2.95, I think.
Go in VirtualDJ
Then go to the "rec" part of the skin as if to record a file. Then clic on "record file" then config, There you will have a file to put, you can browse your folders to find it.
it should normally be this: C:\Program Files\VirtualDJ\lame_enc.dll
