Has anyone experimented with changing fonts to swap out a letter or a number with a logo?
This would look really good with SBDJ Scroll Text Plugin and wouldn't require any changes to the plugin only to the font.
Also I am looking for an ariel font that has a mirror reflection with gradient fade on the reflection.
If anyone knows where I can find one Please let me know because I need one to match the graphics on my showlogo.
Thanks,
DJ James
Thanks,
DJ James
geposted Sun 03 Jan 10 @ 3:26 pm
how do you use a log and change it to a font?
geposted Sun 03 Jan 10 @ 5:55 pm
Would work fine, with the obvious limitations of being a font...
geposted Sun 03 Jan 10 @ 7:13 pm
don't think there is a mirrored font out there the way you describe, with the reflection below the font i take it, you will have to use something like ps to do that.
the other type of mirrored font you can find like this by putting a google in... http://www.maxfonts.com/fonts/p/pr-mirror.font
geposted Sun 03 Jan 10 @ 7:22 pm
I was thinking of taking an existing font and editing one character like a ^ . Something that I wouldn't normally use in a scroll text. Swap that character out with a logo, and save the font as a new font.
Then anytime I want to insert my logo into a line of text I just hit the ^ key.
Seems simple enough but I have not messed with font editing before. I was hoping someone here might have some experience in this and boost my learning curve so I don't have to do so much research.
DJ James
geposted Sun 03 Jan 10 @ 10:36 pm
thats a great idea but how can it be done?
geposted Tue 05 Jan 10 @ 1:58 pm
