Hi Jim, can you make it ????????????????????????
Thxz friend.
Thxz friend.
geposted Wed 11 May 05 @ 9:39 am
Well, Jim that would be a dream come true. :) But I'll be satisfied if anyone would make one, just that it works well.
erXon
erXon
geposted Wed 11 May 05 @ 7:53 pm
I guess I'll have to look into this feature.
Where should I put the 3rd deck though? hmm.... suggestions?
- Jim
- Jim
geposted Fri 13 May 05 @ 5:36 am
This new feature is a little bit disappointing... Well... How is it implemented, anyway.
The third deck has to be in a skin outside the other skin (the skin with deck 1 and 2), which is a major limitation. Hard to do well.
You might aswell use djcel's multiinstance skin. (Good skin idea!)
This new feature just opens two instances, specifies which instance is to use which skin part, and then place them on the screen according to specified coordinates.
- Jim
- Jim
geposted Fri 13 May 05 @ 5:59 am
