With Stealth Control:
Is it possible to map it in such way that rather than working ridiculously like Traktor it can work just like Total Control on VDJ. I found it so annoying to have like 10 different buttons for searching-fast forwarding etc. and no control for sampler and effects. Thanks..
PS. I am not trolling the forum...Can one of the mods please delete the post in Numark Support thread. Thanks.
geposted Mon 04 Jan 10 @ 2:36 pm
It's very possible on the higher version 6.0 up.
But with the LE i don't think so.
geposted Tue 05 Jan 10 @ 2:29 am
i am trying it on VDJ6 new year`s trial at the moment...i think it is quite a full version trial...
if it is not done, i might just switch to traktor as the stealth controller already comes with it...
thanks..
thanks..
geposted Tue 05 Jan 10 @ 7:40 am
Both Omni and Stealth Control are natively supported in the latest version of VirtualDJ Pro, including the v6.0.6 trial.
Even if you don't have the controller, you can see all supported devices and their mappings by going CONFIG -> Mappers, clicking on the button to the right of the drop-down list and then unticking show only connected devices.
You can use the mappers interface above to change the mappings to suit your own preferences. Please see https://virtualdj.com/wiki/VDJscript.html for further information about mapping.
NOTE: You can upgrade from your Numark CueLE to VirtualDJ Pro at a discount by going to https://virtualdj.com/buy/ and entering your Cue LE serial number in the box provided.
geposted Tue 05 Jan 10 @ 12:23 pm
Hye every one, I am using Virtual dj pro and I want to connect my Numark stealth controller. I have really try my best to fix it but I didt get any success. Could any one please help me I will be really thank ful for that.
Greets,
Balli
Greets,
Balli
geposted Sat 15 May 10 @ 7:49 am
Hello,
YOu just need to use a legit VirtualDJ Pro 6.0.8 or our TRIAL download it in here:
https://virtualdj.com/download/trial.html
and you Denon 5500 would work as it should. Using other versions could not let you use your Denon 5500.
geposted Sat 15 May 10 @ 12:11 pm
