Is there a way to increase the font size display in VDJ 1.09?
Right now, it looks like the default is set at 6 or 8 point, and I'd like to increase it to 20 or 24 point.
Any suggestions on how I can do this?
Thanx,
JK
Thanx,
JK
geposted Wed 11 May 05 @ 5:46 pm
open the xml file of the skin
geposted Wed 11 May 05 @ 5:55 pm
24 point are you djing across the room?
DJcel is right all font sizes and colors are adjustable in the skin file, unzip make changes then rezip.
geposted Wed 11 May 05 @ 5:57 pm
Before you edit the xml I recommend to make a backup. Just in case...
Ewout
Ewout
geposted Wed 11 May 05 @ 6:27 pm
Thanks everyone!
I'll make a backup before opening the xml file.
Yeah, 24 point might be kinda big! ;)
JK
JK
geposted Wed 11 May 05 @ 7:51 pm
