how do you put the effects into virtual dj after you download them
geposted Fri 08 Jan 10 @ 1:21 am
Double-click on the installation package that comes with the effect and it will install automatically.
However, the DJ Console Edition is free limited software, so you will not be able to access the new effects from the DJ Console itself. You may be able to trigger them from the Effects tab of the skin using your mouse.
If you upgrade to VirtualDJ Pro, you will be able to map and trigger other effects directly from the DJ Console, use custom skins and much, much more, The RMX Console entitles you to a considerable discount when upgrading to Pro. To receive this, please go to http://www.virtualdj.com/buy/index.html and enter your DJ Console Edition software serial number in the box provided.
geposted Fri 08 Jan 10 @ 12:14 pm
