Hi, I'm a new user, and I have a problem with my Virtual Dj.
When I try to scratch with the jog wheels, instead of scratching, they act modifying the pitch.
I tried to change some configuration, but it's been useless.
What can I do to make my jog wheels scratch instead of modifying pitch?
geposted Thu 12 May 05 @ 12:15 pm
It only works in the full version of VDJ
Not the console version, if that is what you are using?
Download the new 2.1 demo and try
You have to go to controller options in VDJ, and choose jogwheel for scratch also
geposted Thu 12 May 05 @ 3:27 pm
I'm acutally having this same problem in Version 3.3 and 3.4
Scratching is enabled on both Jog and stick. Still not working...any suggestions.
Thanx
Thanx
geposted Tue 07 Mar 06 @ 1:58 am
same as abowe. what to do? first it workd okay but suddenly it stopped.
geposted Wed 12 Apr 06 @ 6:33 pm
Try to reinstall DJC drivers. Jogs and Stick musn't have the same function if you don't use DJC mapper.
geposted Wed 12 Apr 06 @ 8:33 pm
