Athlon 64 3000+ OC'd from 1.8 to 2.2 ghz
1 gig of muskin pc3200 ram
Nvida geforce 6600 oc'd 533 core & 1310 ram pci express version
sata 150 hdd's
foxconn/winfast motherboard
350 watt powersupply
windowsxp sp1 /w wmp10 and codec pack
cpu while playing 2 videos = 39%
I built this system today and its running mpeg-1 flawlessy
geposted Fri 13 May 05 @ 7:36 am
nice ;)
Sounds like a powerfull pc you built :)
geposted Fri 13 May 05 @ 12:16 pm
waou pci express. It should be better than AGP :-)
geposted Fri 13 May 05 @ 2:11 pm
Due the the built in on chip memory controller of the a64 tracks load much much faster one of the first things I noticed. Only one bad thing is cpu multiplier is locked :( I've heard its not of the fx55...
geposted Fri 13 May 05 @ 4:50 pm
Congratulations ! :-) is the quality of the MP1 output exactly the same as if you had played it through a regular media player ?
geposted Fri 13 May 05 @ 6:09 pm
Its similar I'm still testing and playing with codec's and encoders. My latest toy is wmv. I'll report back.c
geposted Fri 13 May 05 @ 6:32 pm
Hey cyder... I have a chaintech geforce fx5500 256 mb... is that one supposed to be really overclockable?
geposted Fri 13 May 05 @ 7:58 pm
the fx series was a bad chapter in nvida's past you can over clock just about any nvidia gpu by installing a litte registry hack called cool bits (google it)
btw vdj chokes on wmv high def getting about 1,2 fps tp be expected from 1280x720 tho...
geposted Fri 13 May 05 @ 11:03 pm
There's the link: http://www.raptor-mods.co.uk/downloads/pafiledb.php?action=file&id=9
geposted Sat 14 May 05 @ 7:48 am
lol... I was going to upgrade this card in the near future.. What do you think is a good option?
Killabee44
Killabee44
geposted Sun 15 May 05 @ 6:51 pm
well if you have the cash 6800 GT :) But if not a 6600 GT will do the job
geposted Sun 15 May 05 @ 6:57 pm
Cyder,
Im actually looking at the evga Geforce 6800 128MB 256-bit DDR AGP over at newegg.com for 199.00 after 30.00 rebate... Its not a 6800GT, but those are more than what I want to spend right now.
Killabee44
Killabee44
geposted Mon 16 May 05 @ 4:29 am
Hmm weird. My last post came out as anonymous.
Killabee44
Killabee44
geposted Mon 16 May 05 @ 4:31 am
killa
Honestly I woudn't want anything but a gt the regular ones don't have the fast ram in them. Go for the 6600gt 160 at new egg right now. I've had good luck with the gigabyte version. Remember slow ram is just as bad as low ram :)
geposted Mon 16 May 05 @ 6:06 am
geposted Mon 16 May 05 @ 6:23 am
Cyder,
Thanks for the article and info. Excellent article. All peeps that will be using video should read it. I will be getting the evga 6600gt today via Newegg. I should have it in a couple of days. Im glad I checked this post before I ordered. :)
Killabee44
Killabee44
geposted Tue 17 May 05 @ 10:03 pm
killia,
A couple of things you should know before you plug that card into your mother board.
1. If you are using an agp version. Make sure you mobo is able to put out the correct voltage this is a 3.3 v card. Make sure you look or you'll be building anothe whole computer :)
2. Power supply make sure you have at least a 350 watt powersupply. You'll notice the extra molex on the card you have to use this connecter or the card will not work.
3. read all instrucrions before you install (don''t make the same mistakes I did)
4. if you are using pci-x then you don't have to do any of the above.
geposted Wed 18 May 05 @ 5:58 am
Damn... My MB is an Asus p4p800-e deluxe.. it only supports 1.5v vid cards. Guess Ill be looking for a new MB.... I might go with another Asus since it is so stable. I have a pentium 2.4 chip in it so ill be getting the Pentium version. Any suggestions on a stable MB with intel chipset?
killabee44
killabee44
geposted Wed 18 May 05 @ 6:48 am
Man, now that I think about it, I might go with an AMD chip instead and sell my mb/cpu. Its probably gonna be better to go with a pci-express vid card instead.
geposted Wed 18 May 05 @ 7:18 am
Sounds like you are doing the exact same thing as me. You'll be glad you did amd 64s will so kick the crap out of anything intel ans pci express is sweet.
geposted Wed 18 May 05 @ 5:37 pm
