Does anyone else experience any type of lag/jitter as the waveform scrolls across the screen?
Its almost like the refresh rate needs to be higher in order to make it run smoothly across the screen.
Im currently running:
Windows XP SP3
AMD Phenom Quad Core
2 Gigs RAM
Numark Cue 6.0.3
Radeon X1300 512M Video Card.
Would installing a better Video card help? My current card is 512M, although its like 3 years old.
it doesnt affect the Audio or Video, and it isnt a big problem. I would just like for the waveform to scroll smoothly across the screen.
Thanks for any suggestions!
Windows XP SP3
2 Gigs RAM
Numark Cue 6.0.3
geposted Mon 18 Jan 10 @ 9:07 am
Did experience something like you mention here also, especially if your mouse is over the scratch pannel.
geposted Mon 18 Jan 10 @ 9:21 am
Does the issue stop by activating the Overclock in the Performance tab ?
geposted Mon 18 Jan 10 @ 10:39 am
Yes.. I think many..
geposted Mon 18 Jan 10 @ 10:43 am
No, it didnt make any difference.
But it looks like the "overclock" selection is for the sound card.
geposted Mon 18 Jan 10 @ 10:53 am
I believe this has been mentioned before on the forum. Would be nice to have the issue resolved.
geposted Mon 18 Jan 10 @ 2:22 pm
Setting "overclock" didnt make any difference in my case either.
I also notice that CUE toggling adds to the issue.
geposted Tue 19 Jan 10 @ 8:50 am
... raises his hand as if to say, 'Happens here as well.'
geposted Tue 19 Jan 10 @ 9:05 am
Here, too. Never really bothers me much because I don't mix visually. For those who do, I'm sure it must be fustrating.
geposted Tue 19 Jan 10 @ 9:08 am
its not "terribly" just a little irritating..
for me its when I'm setting up the CBG, I have to compensate for the jitter/lag when I'm checking if the CBG is dead on or not for my mixpoint..
geposted Tue 19 Jan 10 @ 4:41 pm
I am not a visual mixer but it is scary to look at the screen and see the waves just jumping... even though I know that it's really nothing (well at least I think it's nothing).
geposted Wed 20 Jan 10 @ 10:45 am
I have the same problem on my macbook
but if i use xp via bootcamp i don't have this problem. just in the mac (using leopard snow, and there is no overclock in the mac).
macbbok is 2.4 Ghz, 4 GB RAM DDR3, Nvidia 9400 and 7200RPM 500GB HD.
geposted Thu 21 Jan 10 @ 2:49 am
I've recently noticed in an extensive testing session, that the lag is prominent when you use automix and the next song is loading. After the track loads completely, however, the waveform seems to smooth out somewhat. I just thought this might be useful for some of you ;)
geposted Thu 21 Jan 10 @ 9:16 pm
UPDATE:
I installed a Nvida Geforce 250 in my rig. Jittering improved. Not completely smooth, but much better.
geposted Mon 25 Jan 10 @ 12:20 pm
Ive been djin for a long time now with the kam digi mini and a mac
ive just backed up all my music mostly bought from itunes beatport etc,
and reinstalled virtual dj..
And when im playing some of the songs its starting to jump 1/2 seconds foward and jitter and sometimes will just completey stop
I look like a complete nob because im playing of a pretty loud soundsystem and when it does that they all look me and call me shit !
Will probably loose my residency if this continues, please help extremley fustrating !
geposted Sat 23 Jul 11 @ 7:43 pm
Please do not post the same message more than once.
You have already posted this same message on both the PC and Mac technical support forums. Which computer do you have?
Please see the common performance issues page for either PC or Mac depending on which hardware you own: https://virtualdj.com/wiki/Controller%20Configuration%20And%20Troubleshooting.html
geposted Sun 24 Jul 11 @ 12:50 pm
Try to use skin with the same size of your screen resolution if no one is the same size just don't toggle the maximize button. i got the same problem when i used diff resolution and maximize the skin size.
geposted Sat 30 Nov 13 @ 11:44 pm
