Hi not a great first post but i really need some help on this... (deep breath)
I have an American Audio Radius 2000 midi controller.
I have tried many ways to recognise it in VDJ6.
I downloaded a plugin called VDJ RADIUS V3 which i have put in the correct folder in Documents > Virtual DJ > Mappers
When I go into Virtual DJ application it is not recognised.
My Computer Recognises the controller and drivers and shows Radius 2000,
Under Config > Mappers > Select a controller - i only have keyboard and Simple midi wrapper.
Under the options for this i removed "show only connected devices" and i can see Radius 1000 and Radius 3000...
Thing is the mappers for all the radius series are the same (they have the same map file from ADJ Audio)
I copied most of the code from the other radius files but it took me ages and i still dont have full control as if i were using the Radius V3 file!
Im using windows 7 if this makes a difference.
Cant get it to work on Vista at all, likewise with XP...
Any ideas?
Any ideas?
geposted Tue 19 Jan 10 @ 5:05 pm
The Radius 2000 is not currently supported at this time. We are currently working with American Audio to bring support to VirtualDJ for this unit.
geposted Sat 23 Jan 10 @ 9:29 am
Is the radius 2000 still not supported with VDJ ?
geposted Thu 10 Jun 10 @ 11:53 pm
Radius 1000, 2000 and 3000 are all supported in the latest version.
If you are not running v6.1, please upgrade by going to your Download Center: https://virtualdj.com/download/updates.html
geposted Fri 11 Jun 10 @ 2:33 pm
