Would like to, and need to be able to bring in ambient video on deck 1 or 2 without losing it when loading a MP4 to that deck. Need to dissolve smoothly from one deck to another with this option. nThe only option at this moment that I see is a straight ut from the Effects palent.
It's a pain and not smooth, just a cut in on output monitor only.
Thanks for your help.
Chris
Chris
geposted Thu 21 Jan 10 @ 10:27 am
If you use Clipbank wih your ambient clip loaded for audio-only files, then you can transition to/from it exactly the same as a normal video file?
geposted Thu 21 Jan 10 @ 12:58 pm
